Thread: ECU Flashing??????
Created on: 11/16/13 05:08 PM
bikemanusa
bikemanusa's Gravatar
ECU Flashing??????
11/16/13 5:08 PM
Ok! I am considering flashing my ecu. other then slip ons I am stock and pretty much looking to stay there. Im not all that interested in having more power. I did once read that with a flash the bike will sort of wake up a bit and even run cooler. So instead of searching all over this great 4m I would just let you guys give the pros and cons on all the available flashes out there. Give me your most honest opinions. If your not looking to piss off anyone here or put down there stuff just send me a private. thanks guys. B.T.W. mine is a 2012 14r.
life is a journey, not a destination.
nasty
nasty's Gravatar
RE: ECU Flashing??????
11/16/13 5:15 PM
No piggy backs. More precise fueling. Flash the flies open as through they were no longer there. TC still works flawless. Blah blah blah blah.... And ignition timing adjusted properly.
Forever Fearless
-Clint Eastwood
Neilp
Neilp's Gravatar
Brisbane, Australia
11/16/13 7:38 PM
As far as I am concerned there are NO downsides to a flash, if you don't like simply return it to standard or do another tune!
Neil
11/16/13 9:26 PM
There is flash and there is FueLash.
Flash:
Standard bla-bla are things like, setting only: the 100% flies open/N rpm limit/more top rpm limit/mph unlimited. Lets say this is the quick and dirty flash. Someone cuts and pastes, saves, burns, done deal, pay the cashier.
FueLash:
This is where the big bucks come in someone knows their shit. Auto tune/exhaust gas offset/wideband 02 enable(you find the right 'unused' pin(s)/ignition maps/fuel maps/4-sequence maps. Someone changes these numbers, they better know their processing numbers. Anything else is just guesswork, IMO.
Sheer guesswork is more like I see what is happening. To take some of the guess out of it is it takes a tuning tool like a dyno, or an AFR meter, downloading data so you can see it run with a click of a mouse. It gets more complicated you add a change in ignition maps. What about the filtering in 'auto tune?' What about the 'gas offset?' Who is going to dial in a map with those other options needing changes too? The gas is going to be offset you change the fuel out the pipe. There is your remote AFR change, let alone a drop or rise in tune one plays with the offset lets say.
I'll bet it's one reason Rossi said goodbye to his long time tuner is that he has no clue of the basics? Just mess with the X to Y numbers on a checkerboard? Why, he brought in another old fart into the pits, I'd be pulling a high school hacker out of class, slap the back of his head and say, crack DISS!
And between reading the processing book, looking at the map changes, it's beginning to tumbLeana in the tiny bean HA! Okay, somewatt
11/16/13 10:36 PM
Are you prepping us here for a killer ECU program?I'm still waiting....
* Last updated by: Grn14 on 11/16/2013 @ 10:39 PM *
bikemanusa
11/17/13 9:52 AM
So how do we feel about the brocks/guhls flash?
11/17/13 10:12 AM
I had one of the 'original' Brock/Guhl flashes...and a PCV Brock's map.On my 2012(may she RIP).Also had his exhaust...4 into 1 CT.It was good...not as good as the new ones coming out from a couple of these members here.Brock's was at the time...kinda...buzzy.These new ones are much more refined...and stronger for sure.And NO PCV...not on mine anyway.
* Last updated by: Grn14 on 11/17/2013 @ 10:14 AM *
bikemanusa
11/17/13 10:56 AM
Who is making the newest stuff?
11/17/13 11:16 AM
They're here...on this forum.Two excellent flashers....can't go wrong with either one...I'll just say that.
nasty
nasty's Gravatar
11/17/13 11:40 AM
Both forum tuners are very excellent in their own unique ways. Impressive talent on hand. Both can fine tune to your preference in options.
Forever Fearless
-Clint Eastwood
11/17/13 2:14 PM
bmu, So as to be objective, I left out the home brew and your list of the aftermarket sources. Let those with experience decide who is top banana, or at least took the reach around time to find out.
Who is making the latest stuff? New as in what? Lets run down a few things as far as flash vs. owned.
Q. I'm not interested or capable of buying a unit and attempting a flash, being the latest thing. What should I do?
A. Send your ECU to someone in the aftermarket or if a home grown offers up, you have a few choices.
Q. I'm interested in the latest thing and I have worked with a map, so I have a little 'bit' of experience, what is out there?
A. If you send your ECU out to the aftermarket, be charge the same price for what you can do yourself is buy a flash kit. Say you break even or so close is the cigar, then this is currently as high as you can go, it's a DIY device, you are on your own.
Q. I'm all for every gadget on my bike, what's the latest? Just pack it on, I want it all.
A. Lets start out with a stock bike and open her up. Flash alone with stock pipes is all you need is one step. If you want to tune the bike, then you'll need an AFR meter to download your results or she knocks, overheats, you are blind tuning without it other words. The next installment would be to use all that hot rod [a piggy like a pwrcomdr] to tone down the tune, along with the AFR meter is to run the 02 for best mileage: a second kind of map play.
Q. I'm going to have a toggle that switches off the 02/piggy and I am back with the flash alone? I have the flash tuned to my exhaust choice so I am good to go I turn off one map and, cough with the other I have to swallow my nuts did you say?
A. Yes, that is correct.
* Last updated by: Hub on 11/17/2013 @ 2:19 PM *
11/17/13 2:22 PM
If I get around to a map, I'll send it off to the Wooly site, it's all yours.
11/17/13 3:37 PM
(See how to section, we need Rook to make it understandable). 6 years and new model will be out lol.
bikemanusa
11/17/13 5:19 PM
Hey Romans, I was trying to pm you about the flash you do. But with my phone I can't send a pm. My email is blkbelttony@yahoo.com. could you send me an email with more devils on what your flash is all about. Thanks in advance.
bikemanusa
11/17/13 5:19 PM
Oops! Details not devils. Lol!
11/17/13 9:41 PM
"Devils"...LOL...yeah...you might think so after you run one of these flashesLOL!!!!Best to get a set of Angels on there....just incaseLOL!!!!
bikemanusa
11/18/13 5:58 AM
No pun intended right? Lol!
Daytona955i
Daytona955i's Gravatar
11/28/13 5:54 AM
LMAOF..I have not put enough miles
on my 14 to consider improving her!
I am still in awe of the power straight out
of the crate!!!!!!! That said.
I woukd re-map
my Daytona for whatever mood I was in,from low end grunt to
fuel conservation free maps were available at tuneecu.com to bad
he only does triumphs.
For My 14 I was planning on a Power Comander and a dyno session.
I would prefer to remap the 14? What cable
do I need to plug into the 14s ecu? And where
can I download/buy the maps for the 14?
* Last updated by: Daytona955i on 11/28/2013 @ 5:56 AM *
JP
